Old 09-29-2007, 07:08 AM   #1
Unhappy p1411 & p0410 codes
My 98 Boxter check engine light is on. After I took the car to the mechanic he found faults P0410 secondary air system and P1411 manufacturer control emissions. He said he tested secondary air system, found air pump not coming on, he traces wiring and cleaned all connectors, pump ran, then tested air pump control valve, it was not operating. He changed it. He charged me $600. I brought the car back home and check engine light came back on. I am planning to take the car back to him. Any suggestion as what causes this problem. Thanks.
zack is offline   Reply With Quote
Old 09-29-2007, 01:18 PM   #2
Hi Zack, I had the same codes on my '99 a couple of months ago, here are a couple of links with lots of info. I had the air change over valve replaced at my local indy porsche mech. under $300 No cel since then.
http://www.renntech.org/forums/lofiversion/index.php/t628.html
http://mike.focke.googlepages.com/checkenginelightcausedbymassairflowsensor
later
dave
rockbox is offline   Reply With Quote
Old 10-22-2009, 09:20 AM   #3
Is this the part # to the part you replaced?
996-605-123-01-M244
Thanks.
Gubu986 is offline   Reply With Quote
