Old 08-09-2007, 09:35 AM   #1
blkboxster
Guest
Posts: n/a
Diy gear shifter
I HATE my mushroom gear lever so , i tried searching but found nothing, can someone please give me a write up on how to change my 5spd gear stick ,pics will also be GREAT!!!!!!!
thanks
Old 08-09-2007, 09:39 AM   #2
Send a message via MSN to CJ_Boxster
Oh heres the directions on how to remove the Mushroom shifter, Directions may get complicated but bare with me...
Step 1) Grab knob (not yours) and pull up.
End of Steps. ;-)
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 08-09-2007, 09:42 AM   #3
blkboxster
Guest
Posts: n/a
End of Steps. ;-)
Lol, anybody with any useful steps
Old 08-09-2007, 10:45 AM   #4
Send a message via AIM to blinkwatt
-Get a small flathead or your fingernails around thelower section of the shift knob 'skirt' and gently pry it up.
-My 99' has a small allen wrench gizmo that adjusted the height of the shift knob and also kept the shift knob in place. After that is loosened pull up and it should be loose.
-Installation is reverse.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 08-09-2007, 10:57 AM   #5
Mushroom shifters dont have allen bolts, they are snug fitting and are slipped on with out any mounting hardware, To remove a stubborn knob, open the convertible top and place one foot on the passenger side and one foot on the drivers side and pull up on the knob. It'll slip off.
Carlos J Cazares
Old 08-09-2007, 11:12 AM   #6
blkboxster
Guest
Posts: n/a
Really, its that easy, no bolts to un do,? SO i just pull it off, and slip the new one on
Old 08-09-2007, 11:25 AM   #7
Well unsnap the leather boot from the center console then pull the knob. The new one will install in reverse order but depending on the one you get, u might have to tighten a Allen bolt to secure the new knob.
Carlos J Cazares
