Old 03-16-2008, 10:21 PM   #21
Originally Posted by cmarks20
I'm just looking for something that's a bit more functional and appealing than the standard 986 one. I love the idea of being able to use the on-board computer, but cringe at the thought of installing the stalk.
I did not install 4-stalk yet. You can control OBC with 2 switches also. At the moment I only have 1 switch installed to control everyday needs (scroll one way and reset). I have not decided if I go with a second switch or 4-stalk.
Jake
http://www.jazmine.com/images/avatar.jpg
My FB has lots of pics
01 Speed Yellow Boxster S
- Tip
- PSE
- C4S Cluster with new style OBC
- 18" with 7mm rear spacers
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- Integrated Garage Door Opener
- 986 emblem
- Yellow brake calipers with Brembo stickers
- Yellow center console
- Aerokit II wing & trunklid
- Eibach Pro springs
In memoriam: Black 935 Street
LowFlyR is offline   Reply With Quote
Old 03-17-2008, 04:53 AM   #22
As long as I could scroll through the options and reset, I'd be perfectly happy. Did you find an install guide on here, or just figure it out on your own?
2000 Boxster - Arctic Silver
cmarks20 is offline   Reply With Quote
Old 03-17-2008, 05:16 AM   #23
There Is No Substitute.
rick3000's Avatar
If you google, Boxster OBC Hack, whiteson.com has a great DIY guide. The function you don't get without the second button is speed gonging, which is completely pointless. It allows you to set a speed, and once you reach that speed the car beeps at you. Like I said, pointless!
Old 03-17-2008, 05:46 AM   #24
That is a great DIY. I'm not sure if I want to risk doing it myself though....let's just say I'm not the most electrically inclined. Either way, at the very least, I'll push the techs at my closest dealership to turn on the OBC and see if they can maybe set it to "distance to empty."
Old 03-17-2008, 07:22 AM   #25
My situation is a little different, because I have 01 986S and my cluster is 04 C4S which has new style dot matrix OBC display. I actually cannot reset with one switch, I can see reset screen, but cannot reset without second switch (or 4-stalk). Pressing switch 1 right, I get to this screen and pressing left I can scroll DOWN until bottom. With one switch I have no way to get to "reset all" or actually reset anything (except trip with the left peg). Pressing right again here gets me back to normal screen.
I have wired second switch contacts already, so I know what they do. I just don't have the switch (or 4-stalk yet).
Here is my normal display:
:dance:
My next "project":
More pics @ myspace.
Also rentech.org has a long topic about cluster swap:
http://www.renntech.org/forums/index.php?showtopic=12805
Jake
- Tip
- PSE
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- 986 emblem
Old 03-17-2008, 07:25 AM   #26
Without a switch you only get outside temp display and even if you would get "distance to empty" you could not reset it without a switch. It doesn't reset automatically when you fill your tank.
Jake
- Tip
- PSE
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- 986 emblem
Old 03-17-2008, 07:28 AM   #27
I was afraid of that. I'll just have to suck it up and put a switch in somewhere. How much did you pay for your cluster, if you don't mind me asking?
Old 03-17-2008, 07:39 AM   #28
I got lucky $101 shipped from Ebay. You must be careful with ebay clusters though, that is complicated instrument and you want to get one which works. Read the LOOOONG topic @Renntech, that explains a lot about 996 clusters in 986.
Jake
- Tip
- PSE
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- 986 emblem
Old 03-17-2008, 02:36 PM   #29
rick3000's Avatar
@cmarks20
It is an extremely easy hack. It sounds complicated but it is actual very easy to do. It took me about an hour total, and I had never done anything like that to a car before. Boxster's are designed so incredibly well, that you won't have to struggle with anything.
Old 03-18-2008, 04:50 AM   #30
@cmarks20
That's good to know. I've never done anything like this to a car before either. Guess it's about time to start looking at clusters =)
Old 03-19-2008, 01:07 PM   #31
I've been thinking about a clean way to add a car computer to my 2001 boxster, too. My current thinking is to take one of the Asus EEE laptops and put it in the shelf for the owner's manual. Surprisingly enough, it has the same dimensions as the shelf. So I think it would work. If I ever wanted to remove it, or upgrade to another UMPC or laptop, it would be easy to replace, too.
For the display, I am debating between a 1DIN touchscreen that folds out, or a 2DIN touchscreen. To use the 2DIN, I would have to remove the DSP unit. I'm not sure how hard that would be, but I don't really care about the DSP unit, as long as the factory changer still works without it...
jefftay is offline   Reply With Quote
Old 03-19-2008, 02:05 PM   #32
My thought was that I replace factoty cd-changer with PC (incl. 160GB HD), so I do not need a CD player. 160 takes quite few MP3's. I'm also planning 7" touchscreen in top 2 Din slots.
Jake
- Tip
- PSE
- Litronics
- Fully de-ambered
- LED taillights
- Aluminium Pedals
- 986 emblem
Old 03-19-2008, 02:59 PM   #33
boxster6354's Avatar
'nother carputer
http://gthing.net/carputer-5-final/
