Old 07-09-2007, 08:48 PM   #1
Octane booster useless?
If it rises the octane by .1 or .2
Whats the point of octane booster?
We in Costa Rica have 87 octane (our premium) so I was thinking of using octane booster, after reading only rises .1 or .2 the octane, whats the point of that product?
Why is even made and who buys it.
Am I missing something?
motoadve is offline   Reply With Quote
Old 07-10-2007, 01:27 AM   #2
You're missing the fact that most people who buy octane booster don't understand how to calculate the true octane in the tank.
Let's say you had 9 gallons of 87 octane and added one gallon of 114 octane Toluene (a pure hydrocarbon, used to be used by F1 teams back when they were making over 1200 HP). Well, 9*87 = 783. 1*114 = 114. (783 + 114) / 10 = 89.7.
By spending $10 on a full gallon of Toluene, you only raised your already half-empty tank by 2.7 octane points. In the US, that's the difference between regular and mid-grade. People who dump in a few ounces of anything are totally kidding themselves.
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
Old 07-11-2007, 06:20 AM   #3
Octane Rating
The octane rating is a measure of the auto-ignition resistance of gasoline (petrol) and other fuels used in spark-ignition internal combustion engines. It is a measure of anti-detonation of a gasoline or fuel.
Octane number is the number which gives the percentage, by volume, of iso-octane in a mixture of iso-octane and normal heptane, that would have the same anti-knocking capacity as the fuel which is under consideration. For example, gasoline with the same knocking characteristics as a mixture of 90% iso-octane and 10% heptane would have an octane rating of 90. (from wikipedia but accurate)
It is experimentally derived by running the fuel through test engines and comparing the results to various iso-octane/heptane mixtures. As a result some compounds (toluene and xylene for example) will have octane ratings greater than 100%. Volumetric mixing ratios will not necessarily allow you to "blend" a desired octane level since this is an experimentally derived property not a true volumetric ratio it is not as simple as 1/2 tank of 90 octane plus 1/2 tank of 100 octane yields 95 octane. It is safe to say you have something between 90 and 100 octane but without running the new blend through the test engine what you have is at best a guess.
There are octane additives that can be added at less than 1% volume ratio (i.e. 1ml per 100ml) that will increase your octane 2 percentage points. Unfortunately some contain tetra-ethyl lead which is great for the octane boost but bad for the catalytic converter and the human body. So read the all the warnings and ingredients.
The answer to your original question is that there are octane boosters that will get you to 91 octane from 87. However, if 87 octane is all that is available in Costa Rica and Porsche sells there I wonder what is up. Is the octane rating listed as MON on you pumps or RON or the combined (R+M)/2? Without going into the differences, MON is typically about 10 points lower than RON and therefore your combined would be about 91/92 in the US (we use the combined sometimes called the AKI or anti knock index.)
Hope this helps.
ATB,
Tom
trube78 is offline   Reply With Quote
