07-07-2007, 08:55 PM
#1
Two problems with new 07 Boxster
Here are two problems I have encounter with my new 07 Boxster in the first week of ownership: First, the alarm goes off by itself periodically. I was sitting at Starbucks looking at my car outside and all of a sudden the alarm goes off. The car was about 5 meters from me. Today the same thing happed to me. It does not do it at home when it is parked but only on the street. What can cause that. Also, the Boise radio periodically says "STOP" on the panel and will not play anything -CD or radio and no matte what I do it does nothing. So far after a while of fidgeting it goes away. what can cause this/
thanks for the info
07-07-2007, 08:58 PM
#2
I'm not sure on the cause but this obviously isn't normal, some kind of electrical thing, maybe a fuse.
I would contact your service advisor and get the car in under warranty.
05 987 S SOLD
Arctic Silver
Bose/Xenon
05 Touareg V8
Black
07-07-2007, 10:03 PM
#3
thanks for the info
IT could be the motion sensors inside the car getting set off...
Lamborghini Murcielago (current)
Supercharged Viper SRT-10 800 HP Special Edition #49 of #50 (current)
Ferrari 360 Spider
Lamborghini Diablo VT Roadster
911 Cab
Boxster S (current)
08 Hummer H2 (current)
BMW Z3 (current)
Limos in Ohio and PA - First Class Limo Columbus Limos
http://pteam.net/avatar3.jpg
my car collection *Porschephiles agree, Desnorkify your Porsche!*
07-07-2007, 11:31 PM
#4
That sounds like it because the two tims it happened it was parked on busy streets.; Is ther a way to desensitize the motion sensor?
07-08-2007, 11:47 AM
#5
The '07s have a hidden owner viewing sensor designed to reduce the
hours wasted by owners looking at their cars. It's pretty sensitive,
so just stop looking at it.
- Mark
07-09-2007, 11:00 AM
#6
ohh, been a long time since I've posted but I had this same thing when I first got my car and it turned out that I was putting a sun blocker thing in the window and as it heated over time it slowly moved setting off the alarm... that was such an annoying and weird problem to diagnose! Maybe that helps?
07-09-2007, 12:00 PM
#7
the stop message on the CD player I got every once in a blue moon....usually occurred after putting in a cd that I burned from my pc.....fidgeting got it to go away
07-09-2007, 01:19 PM
#8
thanks for the info
I have experienced this issue a few times too - ejecting the disc and putting it back in usually solves the problem.
Congrats on your purchase.
07-09-2007, 01:37 PM
#9
You can press "TP" + dot button 1 + dot button 3 to reset the system and bypass the STOP message. Sometimes turning on and off isn't enough.
I agree with Super66 that burned CDs seem to cause this messsage to appear more frequently. I also find the message more likely to appear with high ambient temperature (like we've been having lately in CA). BTW Super66, I notice you changed your pic recently and must say your rims look great, although I'm still not sold on the Cayman grills.
I'd be concerned about your overly sentive alarm. I've trafficked 987 boards for a couple of years now and never heard anyone complain about this problem before, where it seems that everyone has experienced the "STOP".
http://i7.tinypic.com/24ovngk.jpghttp://i7.tinypic.com/24ow0id.jpg
06 987S- Sold
Carrara White / Black / Black/Stone Grey Two-tone
05 987 5-speed - Sold
Midnight Blue Metallic / Metropol Blue / Sand Beige
06 MB SLK350- Lease escapee
Iridium Silver Metallic / Black
We've heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true. - Robert Wilensky
07-09-2007, 01:39 PM
#10
Hey thanks, that's helpful
07-09-2007, 01:53 PM
#11
You can press "TP" + dot button 1 + dot button 3 to reset the system and bypass the STOP message. Sometimes turning on and off isn't enough."
That IS helpful. Clarification? You mean push them all at the same time (like ctrl/alt/del) and not sequentially, yes?
- Jim
2000 Boxster S, Speed Yellow, Michelin AS/3 tires, 60,000 miles...
... and climbing.
07-09-2007, 02:08 PM
#12
Yes I mean at the same time. It looks like you have a 986, in which case it's TP + 1 + 4 (I believe?).
06 987S- Sold
07-09-2007, 02:27 PM
#13
I do, and thanks, SD987!
- Jim
... and climbing.
07-09-2007, 03:25 PM
#14
Never heard about the alarm issue, but the STOP issue is prevalent. Porsche admits no wrongdoing and will blame your CDs for the issue.
Complain to your Porsche service rep and get in the chain of having them replace your unit in hopes that you have a defective one. Once they've done that a few times you'll find that the problem still exists and that no one in Porsche has a solution.
You can then contact Porsche Customer Commitment (the number is in your owners manual) if you are still peeved about the issue and see what kind of appeasement you are able to wring out of them.
The whole thing's a lengthy process, but I'd say it's worth doing.
I pray that Porsche will get a decent supplier for their stereos someday. I believe the prayers are futile though.
07-09-2007, 10:20 PM
#15
Thanks for the Stop issue information. i will check it out. As for the alarm. It occurred once with the top down so the motion detector could not have been the problem. Any other ideals, This is a real problem for me.
