Old 07-06-2007, 03:55 PM   #1
Unhappy caliper clearcoat coming off
The clearcoat is coming off one of the red calipers on my 2002 Boxster S. Paint is still on, just seems to be the clearcoat. Just looks dull where it came off. Anyone else had this problem, know a solution or the best way to fix?
Rondo is offline   Reply With Quote
Old 07-06-2007, 04:25 PM   #2
Must be something about the '02 S, I have the same issue. The only thing I can think of is to remove them and hand sand them. I would think we would have uneven lines in the without getting all the clear off. Alot of nooks and crannies there Not looking foward to this one.
http://i122.photobucket.com/albums/o...986/986sig.jpg
2002 Boxster S
SC986 is offline   Reply With Quote
Old 07-06-2007, 04:45 PM   #3
Pat
Your best bet is to remove them, have them sandblasted and powdercoated. Considering the heat calipers endure, not to mention corrosive brake dust, that is the only thing that will last. I have personally used high-temp paint, and G2 Caliper Paint myself. The stuff just doesn't last, even with perfect prep work.
Pat is offline   Reply With Quote
Old 07-06-2007, 10:50 PM   #4
If you're going to do anything about it, pull your calipers, rebuild them, have them blasted and powder coated, and enjoy life after that
Otherwise you could just live with it.....
Patrick
Old 07-07-2007, 07:10 AM   #5
my 2002 s did the same thing. It looked bad until I went to the car wash and power washed the rest of the clearcoat off. At least now it is all one color, a dull red.
James
2002 S
jhandy is offline   Reply With Quote
