Old 06-30-2007, 02:25 AM   #1
ehD
convertible top not working after battery disconnect?
hi, i disconnected the battery to disarm the airbag to fix my sensitive horn.. well my torque bit was too fat.. but anyways when i reconnect the negative cable, i lost my radio code which im sure is normal but my convertible top seems to be stuck open... i cant close it. i hear no reaction when i push the close top button with e-brake on. does the radio code not being inputted affect this? also im not sure if my top is completely in the car.. as i dont remember how it looks like.. but theres gaps on the left and right side of where the top is stored... is that normal.. i thought it used to be flush but i could be wrong.
help! thanks
ehD is offline   Reply With Quote
Old 06-30-2007, 04:07 AM   #2
There should not be big gaps or uneven. Having or not having radio code does not impact top. Not to sound simplistic, but are you sure the e-brake is pulled up and light showing as such on dash? What about the micro switch where the center latch goes - do you have a the infamous red clip & forgot to move it? I sometimes do (especially since I painted mine black to match).
If you e-brake light is not showing on the dash, your switch there could be going bad. Give it a few easy pulls (one or two notches) to see if that works. If not, then try a few hard pulls.
Since you're not getting any top motor movement or sound, I suspect it's either the switch in the e-brake or micro switch at center latch.
Old 06-30-2007, 05:49 AM   #3
Send a message via Yahoo to Chills
+1 to what Burg suggested. I'd also check out the fuse box to make sure you didn't pop one when reconnecting the battery.
I bleed green
It's not about the summit, it's about the climb.
http://i133.photobucket.com/albums/q46/chills1138/2.jpg
Chills is offline   Reply With Quote
Old 06-30-2007, 10:33 AM   #4
ehD
awesome, ur right, the e-brake light wasn't on. somehow tho, it works now after a few e-brake tries.. i donno how to check out a burned fuse. anyway now i gotta figure out this radio code thing which i think is all over this forum.
THANKS BURG and CHILLS
Old 06-30-2007, 10:54 AM   #5
Glad it was a quick fix.
To check your fuses open up the fuse box. Its by your left foot. There's a fuse puller in there. Just pop them out and see if the connection is broken.
I bleed green
Old 06-30-2007, 12:05 PM   #6
Get that e-brake switch replaced. It's a $5 part, and if you're a DIY-er, there are some how to's out there. It should be very easy.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
http://www.zoto.com/frayadjacent/img...f27a-4a399.jpg <---- my car. ^ crap I post.
"The existence of the flamethrower is evidence that someone, somewhere once said 'I want to set those people over there on fire, but I don't want to have to walk over there to do it.'"
FrayAdjacent is offline   Reply With Quote
