rim/wheel question
does anyoe know if 18x8 wheels will fit all around the 986? thanks.
Don't suppose the Boxster design engineers
put different sized wheels on the car from the factory for a reason? Maybe handling, clearance, etc.
I believe they will but, I'm not sure why you'd want to.
i saw some aftermarket cayman wheels on ebay and the fitment was 18x8 all around and didn't seem to be staggered that's why i'm asking..
Cayman / 987 wheels have the wrong offsets for a 986. Got to make sure you have the proper offset or you'll make an expensive mistake. The factory wheel size and offsets for 18" 986 wheels are:
Front 18x7.5 50mm Rear 18x9 52mm If you go 18x10 rear, the offset should be 47mm. 987 factory numbers: Front 18x8 57mm Rear 18x9 43mm You could use a 7mm spacer on the front, but the 987 rears just won't work. |
| All times are GMT -8. The time now is 09:40 PM. |
