Old 06-13-2007, 03:57 PM   #1
Question about offsets
I currently have 18X10 et52 rear wheels with 7mm spacers, which reduces my offset to 45. The tires that I have on the wheels are 265/35. Can I go with larger tires, like 275/35 or 285/30 without rubbing the struts or fenders?
Here are the tires:
Toyo Proxes T1R 285/30/18 have an overall tire width of 11.2
or
Toyo T1R 275/35/18 have an overall tire width of 10.7
I have a MY00 Boxster with the standard suspension, however I may upgrade to the M050 ROW set-up later.
Duster is offline   Reply With Quote
Old 06-13-2007, 04:10 PM   #2
It will be close - but should be OK (+/- 3MM)
We are at 42MM offset with 285/30/18 KUMHO V710 on 10" wheels and H&R lowering springs.
The tire diameter is important also - due to the spring location
Take care
Sboxin is offline   Reply With Quote
Old 06-13-2007, 04:49 PM   #3
Toyo tire diameters
For the 285/30 its: 24.7" (Fully inflated)
and the 275/35 its: 25.6" (Fully inflated)
Old 06-13-2007, 08:18 PM   #4
Sounds close. Why are you set on running wider than 265/35? Unless you're on a suspension that can compensate, all you're going to get is more understeer....
Patrick
