Old 06-08-2007, 09:17 AM   #1
shifting
I noticed the other day that when I shift and the car is in gear, there is a lot of play in the stick. I was thinking of my 944 Turbo and don't remember it being anything like that, it was real tight.
can this be fixed with a short shifter kit or just the upgraded linkage?
yellowboxster01 is offline   Reply With Quote
Old 06-08-2007, 09:36 AM   #2
Mine also, I have 110k miles on my linkage, how many miles do you have on the car?
I have side to side play on my linkage. I usually have to pull the shifter really hard to the left while engaging 2nd gear so not to cause it to grind.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 06-08-2007, 12:23 PM   #3
I have under 25k miles on mine. it's just a sloppy felling in the stick. when i let off the gas and put my hand on the stick then hit the gas again, I feel the stick move.
Old 06-08-2007, 12:35 PM   #4
Ahhh that sounds like engine or tranny mounts taking a dive. I know you can fill your engine mount with urethane to cure the engine mount issue but unsure of how to handle tranny mount whoa's...
Carlos J Cazares
