Old 06-01-2007, 05:03 PM   #1
Garmin Nuvi 360
I just ordered at Nuvi 360 and will be using it mostly in my other cars but wondered if anyone had pics of one installed in a boxster? I do not want to drill or glue anything to the dash or make a permanent installation. Thanks.
1999 Porsche Boxster Built in Germany
Arctic Silver / 17" Wheels
Full leather Interior / Tiptronic
Heated Seats / Cruise
Traction Control / Factory Hardtop
Bumper Plugs / Zaino Z2 Z6 Z8
jci-joe is offline   Reply With Quote
Old 06-01-2007, 05:47 PM   #2
Peer's Avatar
This is how I mounted my GPS:
Pull a GPS cable...?
-- peer
Peer is offline   Reply With Quote
Old 06-01-2007, 06:30 PM   #3
You are gonna love the 360. I got on a couple of weeks ago and it is a great GPS. I have a problem with the suction cup though. It seems to fall off quite a bit. I moved it to the extreme lower left of the windshield right above the vent. This way if it falls it will only fall a half inchand the wire tucks up neatly under the guage cluster cover. I left my camera at work so I cant take a photo but I am sure you get the idea.
Enjoy the 360!
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
der Geist is offline   Reply With Quote
Old 06-02-2007, 06:58 AM   #4
peer,
i was looking at your thread, and wondering how you mounted the gps unit where you have it...that's where i'd like to put my nuvi (350), but i am not sure how to do it...TIA
mb986 is offline   Reply With Quote
Old 06-02-2007, 10:17 AM   #5
I have the Nuvi 360 also and I love it. I have only used it once in the Boxster (Tail of the Dragon trip) because I usually have it mounted in my company car.
I did a cheesy temporary mount which looked great and worked great.
I have an '02 with the cupholders in the center of the dash up high. If you have the older interior Boxster, this won't work.
I extended the right cupholder and then placed the Garmin Mount that comes with the Nuvi inside the cupholder and it wedges in there well. I did not use the adhesive ring supplied with the Nuvi in the bottom of the cupholder, but would recommend it if I was going to use the GPS in there all the time.
I then routed the power cable around the side and fed up under the passenger side rear of the center console and plugged in the power adapter and fed the extra cable under the trim. It came loose a couple of times but that is only because I didn't use the adhesive disc and would be very solid with it and not disrupt the look of the car if you took it out at any time and pushed in the cupholder.
It worked great, looked great etc. The higher position is much safer as far as not looking away from the road as in the other pics where it is lower in the car.
I can take a pic and send to you if you like.
Jeff Wilson
1989 911 Cabriolet
Grand Prix White/Black
33k
Stock except:
Turbo 7x9 Fuchs
SOLD!
2002 986S
Seal Gray/Black
Painted Center Console
18" Turbo Twists with rear spacers
Tequipment aluminum shift knob
Colored center caps
De-ambered tail lights/side markers
Stock except:
B&B catback exhaust
http://i29.tinypic.com/i6crck.jpg
jwilson95 is offline   Reply With Quote
Old 06-02-2007, 10:18 AM   #6
Now I see your pic is '99 and this won't work, but maybe for the 2000 and up guys...
Jeff Wilson
1989 911 Cabriolet
33k
Stock except:
Turbo 7x9 Fuchs
SOLD!
2002 986S
Seal Gray/Black
Colored center caps
Stock except:
B&B catback exhaust
