Boxster General Discussions
Clutch replacement question?
05-29-2007, 07:44 PM
docdyh
How does one tell if a new clutch is needed?
There is no noticeable slippage, but there is increasing play in the clutch. I need to rev higher to get the clutch to engage/disengage. I have only put 6K miles on the Box. My other car has 146K miles that I have driven with the original clutch.
2002 30K
05-30-2007, 03:22 AM
2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Garage
2001 Porsche Boxster
2007 Carrera S Cabriolet
If there's no slipping, then just bleed the clutch fluid. It will improve the feel of the pedal and clutch actuation.
05-30-2007, 09:01 AM
3
aBsOlUt
I have the same problem, engaging and disengaging gears is very hard on the car hot or cold.
I do not believe is me as I have driven many other cars and I am doing more than fine.
Sometimes when I down**************** from 3rd to 2nd the car shakes a bit while its engaging the new gear...
Dealer has said numerous times "No problems found".
Any ideas???
Hybrid Mode
Switch to Threaded Mode
03:15 AM
