Old 05-12-2007, 09:23 PM   #1
Exclamation Rims Not fitting on 06 Boxster
Hey guys im a newbie.
I bought some RPK 038 wheels (9 by 10.5 Rear) with some 275/35/19 tires in the rear for my 06 Boxster. The Tires are hitting the shock in the REAR, so I put 5/16 " universal spacers but that wasnt nearly enough. I measured that I will need about a one inch SPACER. I know this is probably not the best way to go, but seems like my last option. Will I run into any problems and will my 2006 Boxster look like one of those lowriders with the wheels sticking out???
PLEASE HELP ME
Boxster06 is offline   Reply With Quote
Old 05-13-2007, 03:34 AM   #2
Send a message via MSN to hk987
i have 19x10 rear and seem to be fine. what offset are you runnng? also, 275-35-19 sounds too big a tyre to me. some guys are running 19s and 20s on renntech, not sure if any help there...
Wayne @ Hong Kong [2005 Boxster 987 "S" 3.2L]
hk987 is offline   Reply With Quote
Old 05-13-2007, 06:30 AM   #3
You can run 275 tires on the stock setup for a 987. The problem is the wheels are too wide. You will need to go with a very large spacer to make it work. That might be fine for normal driving (so extra tire wear) but I wouldn't take it on the track with that setup.
05 987 S SOLD
Arctic Silver
Bose/Xenon
05 Touareg V8
Black
drburton is offline   Reply With Quote
Old 05-13-2007, 07:51 AM   #4
It always helps to check the required offset BEFORE purchasing wheels....
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
Old 05-19-2007, 09:41 PM   #5
Problem solved
Problem Solved:
I guess when I broke my old rim I bent the knuckle a few mm, causing the wheel to rub the shock. After replacing the part the wheel now fits perfectly. thanks for your help guys.
Old 05-22-2007, 06:51 AM   #6
Originally Posted by Boxster06
Problem Solved:
The Knuckle? What part is that?
porsche986spyder is offline   Reply With Quote
