Old 05-09-2007, 09:11 AM   #1
Radio removal - question
I just bought the radio removal tool. How do I use it? Do I insert the tool all the way in or half way in or what?? I don't want to break anything, so I am asking. It seems like I have to use a lot of brute force to yank it out.
porschedude is offline   Reply With Quote
Old 05-09-2007, 09:18 AM   #2
i believe security clips are on lower part of the radio and they seem to be spring loaded. instead of using the tool, i took the assembly out and used screw driver from the back. if you have the tool, i would think you insert them through top portion of the radio on each side all the way in, lower them to push the security clips in then pull the radio out by pulling the radio face plate. i don't think you have to worry too much about breaking anything though.
spark00 is offline   Reply With Quote
Old 05-09-2007, 09:25 AM   #3
Send a message via MSN to tiggsy
Which radio is it. The CDR23 sometimes requires quite some force to pull it out.
http://www.inaneasylum.org/users/fir...8314_thumb.jpg Best wishes Tiggsy
tiggsy is offline   Reply With Quote
Old 05-09-2007, 09:28 AM   #4
The CDR/CR-220 also takes a lot of pull to get out.
Your tool should say "Top Left/Top Right" Just make sure you put those in the correct spots and pull away.
I bleed green
Old 05-09-2007, 09:39 AM   #5
It is for CDR 220...sounds like i have to use a lot of force to pull it out. I'll give it a try. Thanks for all the response.
Old 05-09-2007, 10:50 AM   #6
TriGem2k's Avatar
Send a message via AIM to TriGem2k
You will know when the tools are property inserted. They will CLICK in and not come out until the readio is removed.
Once the tool clicks in you have to push the tools away from each other and then pull the radio out. It will require some strengh.
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 05-09-2007, 08:25 PM   #7
Agree with previous poster -- there will be a click.
I didn't do this but have seen it done -- you can put a tapered screw driver through the finger holes in the tools to give you more leverage pulling it out.
Once out, you have to press on the side of the radio to release the tools.
I had trouble putting the radio back in - wires in the way. I believe you can remove the cup holders above (at least they were above the radio in my Box) to help with the reinstall.
2003 Audi A4 Avant 3.0/6MT - Orient Blue/Beige
2002 Porsche Boxster 5spd - Seal Gray/Black
1990 BMW 325i (convertible) 5spd - Red/Beige/Black Top
larryshomework is offline   Reply With Quote
