Old 04-24-2007, 04:24 PM   #1
Tire fitment question
Does the wheels and tires for MY' 99 Boxster fit into MY' 94 968 with out additional parts/spacer to buy?
Here's the wheel width: 7" width front 8.5" width rear
"Here's the tire size: F - 225/45 ZR17 R - 255/40 ZR17
unklekraker is offline   Reply With Quote
Old 04-24-2007, 05:21 PM   #2
Send a message via AIM to blinkwatt
You may want to check in the 968 forum on Rennlist.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 04-24-2007, 05:48 PM   #3
thanks for suggestion
Old 04-24-2007, 06:59 PM   #4
The important spec is "offset". That will let you know if you need spacers/adaptors to fit the wheels on cars other than your boxster.
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 04-24-2007, 07:11 PM   #5
@racer_d...you know what are the offset for the 99" Boxster?
Old 04-25-2007, 07:30 AM   #6
This 968 was at the tech session at Don's AutoWerks in Campbell 2 weeks ago. I did not look to see if it had spacers.
Tool Pants is offline   Reply With Quote
Old 04-25-2007, 08:24 AM   #7
Off hand I don't the offsets. It may (should?) be stamped on the rim itself. On my stock 18" wheels there is an offset stamping. My guess is its around a 50 or 52 mm offset. Mine is located right near the valve stem.
1978 911 SC (sold)
