Old 04-06-2007, 11:26 AM   #1
1124 & 1126/MAF
I'm throwing the (apparently) somewhat common 1124 and 1126 codes, and a third which I can't remember, which I believe is the gas cap *gr*.
Anyway, I've read just about everything I can find about the 1124/1126 issue, and it seems like there are two common solutions: new MAF, or theres a vaccuum leak someplace.
I started taking a look at MAF's and am just a little confused. I'm looking for an Air Flow Mass Sensor, and not the Air Flow Mass Meter, correct? This is all assuming that it IS the MAF in the first place.
Also, I believe I read that some people have tried just cleaning the MAF itself before bothering to replace it?
I have to get the car inspected next month, and since I don't think I can reset the code and have it stay off long enough to get it inspected and clear, I think I need to take care of this soon.
Any help is appreciated
http://farm1.static.flickr.com/211/4...7e5359a2_o.gif
Owned: 11 months
Miles: 78,000
Autocrosses: 22
Track Days: 1
http://www.crife.net
986 Girl is offline   Reply With Quote
Old 04-06-2007, 11:34 AM   #2
Send a message via AIM to blinkwatt
Follow these steps and eliminate them one by one;
-Smoke test the intake
-Check your AOS for any leaks
-Clean your MAF w/ electrical contact cleaner
-Replace the AOS w/ 'j' tube ($105 or so from Sunset)
-At this point I would take it to an indie to have it checked out because the MAF is $240+ and o2 sensors are $480+,you don't want to waste money on the wrong part.
Good Luck!
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 04-06-2007, 12:47 PM   #3
fab
fab's Avatar
why can't diagnostic codes be more simple. It's always it could be this.... or could be that....Are all other cars like this? I've never has a CE on my BMW so I wouldn't know.
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 04-12-2007, 06:21 AM   #4
Just for the record, here's what it turned out to be.
1. Crank case breather vent case is cracked which is making it run lean.
2. Check valve for the air pump is leaking.
Also need to be fixed, but aren't the cause of the cel
1. A bunch of leaking gaskets giving me a bunch of little oil leaks.
2. Outter portion of the throttle cable is frayed.
Total, parts & labor: $1200
Owned: 11 months
Miles: 78,000
Autocrosses: 22
Track Days: 1
Old 04-12-2007, 07:00 AM   #5
Send a message via AIM to djomlas
ouch, but at least now you know the problems and can fix them.
goodluck
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 04-12-2007, 07:01 AM   #6
Send a message via MSN to CJ_Boxster
Good Luck!
If one were to perform the smoke test, where would be the best input source for the smoke? Last time a mechanic ran the smoke test, he pulled the vacum hose from the FPR but no smoke leaks detected anywhere.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 04-12-2007, 08:45 AM   #7
goodluck
Yeah, my mechanic is extra thourough, and knows me and my driving styles very well. Thankfully he said a lot of this is all going to be work in the same area/requiring the same prep work, so doing it all now cuts down a lot of labor and such.
Ah well, I gotta have a healthy baby if I'm going to beat on her for the next couple months at the track and autocross!
Owned: 11 months
Miles: 78,000
Autocrosses: 22
Track Days: 1
