Old 03-20-2007, 07:10 PM   #1
CDR-220 Issue???
Just picked up an '02 Boxster S with 24000 miles and all I can say is what a car. This car puts my '04 Z4 to shame in so many ways with the exception of the stereo. Very weak but that was not a decsion factor in moving to the Boxster. Although you must have tunes for a good top down drive.
One thing I noticed is that when I listen to the radio both dash speakers work yet, when I listen to a CD only the driver side speaker works. To me that rules out a connection issue so would y'all say the head unit is bad?
Jeff
beersnob is offline   Reply With Quote
Old 03-20-2007, 08:17 PM   #2
Could be anything. But, first things first. Remove the Faceplate and using a Q-Tip and some Rubbing Alcohol, clean all the contacts on both the Faceplate and the HU. This clears up so many issues with the Porsche Radios, it's the first thing anyone should do...
Happy Motoring!... Jim'99
Old 03-20-2007, 10:26 PM   #3
TriGem2k's Avatar
Send a message via AIM to TriGem2k
If the car is not equipped with rear speakers and the Fader is set all the way to the rear in CD Mode then you will only hear the drivers and not the dash. Check the Fader. This will vary from mode to mode. CD, CDC, FM1, FM2, AM all have independent settings. Check each one individually.
Hope this helps.
James
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 03-21-2007, 08:06 AM   #4
Def recommend cleaning the contacts and checking the fader/balance controls. Also, try a different CD if you havent already. If all else fails, and your head unit is in fact, bad, I have a 6 month old refurbed one for available for sale.
Patrick
Old 03-21-2007, 11:00 AM   #5
Does anyone know if a CR23 will fit my 97 boxster that originally comes with a cr-210?
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 03-21-2007, 11:39 AM   #6
TriGem2k's Avatar
CJ
I think the CR23 uses the fiber optic cables Porsche starting putting into its cars in 2003.
-Side Skirts
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Alpine PDX 5 Amp
