Old 06-16-2018, 04:59 AM   #1
Cunningr's Avatar
Help top stuck down
Looks like my e-brake switch failed and my top is stuck open.
When I pull the ebrake lever the light doesnt turn on showing the brake is engaged, so i think that is the culprit. I opened the panel on the console brake lever left sude but I cant see the switch. Does it require pulling the consol to replace the switch?
And second question, is there an easy way to get the top closed? I have underground parking and the car is covered but dont trust anybody to mess around.
Crazy only had the wheel spacers installed tire off spacer tire on. Lol
Old 06-16-2018, 08:20 AM   #2
Cunningr's Avatar
Update! I managed to get the ebrake micro switch to engage long enough the get the top up. So definately broken switch causing the problem. So looks like i can replace it or bend pin 15 on the relay and solder in a ground to bypass the problem.
