Old 09-08-2020, 01:23 PM   #1
Will there be cake?
tonythetiger's Avatar
WTB: coolant flange
Need to buy the part at green arrow, opposite side of thermostat, inlet flange. Mine has a tiny crack in it. 2002 tip 3.2, if it makes any difference.
Old 09-09-2020, 07:58 PM   #2
If it’s the same part on a 99 5-speed, let me know, you can have it.....
-Eric
Eric-986 is offline   Reply With Quote
Old 09-10-2020, 07:31 AM   #3
78F350's Avatar
No difference between the years or base vs S, but there is a different part number for the Tiptronic (M249) vs the manual transmission (M480/M481). Not sure what the difference is and I have swapped the engines with no need to change that part.
I have one or two if Eric's doesn't work out.
Old 09-11-2020, 04:55 PM   #4
Will there be cake?
Shows a nipple on the tip, but this tip has no nipple. I got it handled, turns out the hose clamp failed, looked like a crack in the flange. All good
Old 09-16-2020, 04:56 PM   #5
Heya -- dumb question, what's the other end of this connect to? Directly to the radiator? Does someone have a larger diagram?
beater986 is offline   Reply With Quote
Old 09-17-2020, 06:26 AM   #6
Will there be cake?
Direct to rad, the part circled and even though the drawings show a different piece for tiptronic, mine didn’t have an extra hose nipple on it. I sorted my issue with dye and found several (3) failed hose clamps. When I replaced them, the leaks stopped.
