Old 09-02-2019, 07:04 AM   #1
Artist, 986S tinkerer
NewArt's Avatar
Bilstein B6
I have a set of B6 struts that are about 2 seasons old. When I went to H&R lowering springs, I found out that I should have B8 shocks due to the adjusted height. Is there any interest here for a good set of B6s ? I figure about $450 USD shippedfor the set.
Old 09-02-2019, 08:37 AM   #2
I may be interested in the rears.
Cosmo Kramer is offline   Reply With Quote
Old 09-04-2019, 04:38 PM   #3
would these be the same fit for a 97 base? Although i'm guessing shipping across the border would not make much sense.
dav9515 is offline   Reply With Quote
Old 09-04-2019, 05:15 PM   #4
NewArt's Avatar
Im not sure about the fitment. You might do a bit of research. My car is a 2004 Boxster S. Shipping shouldn’t be too bad. I can check if you find that they’re a good fit.
Old 09-05-2019, 10:50 AM   #5
NewArt's Avatar
$450 shipped? Seems reasonable.
Old 09-05-2019, 11:22 AM   #6
The Radium King's Avatar
my understanding is that they are the same as oem - one is used for standard suspension and the other for m030.
Old 09-05-2019, 04:38 PM   #7
if you have the part numbers i can cross reference. Also, for clarity, when you say they are 2 seasons old have you been running them for 2 years with the H&R lowering springs? if so about how many miles did you put on them lowered? Thanks
Old 09-05-2019, 06:59 PM   #8
NewArt's Avatar
The B8 is shorter. Apparently the stock strut is equivalent to a B4 and the B6 is a performance upgrade. The B8 is the same as the B6 but shorter to give the proper pre-loads when using lowering springs. In my case, with H&R lowering springs, the B6 shocks will not be loaded enough to give me the optimum performance.
Old 09-05-2019, 09:38 PM   #9
isn't m030 lower? perhaps the euro version, where row m030 is lower than na m030?
Old 11-06-2019, 07:17 PM   #10
Still available?
CigarGabe is offline   Reply With Quote
