Old 02-06-2017, 10:00 AM   #1
AZ986S's Avatar
Used secondary cats worth anything?
Pulled my secondary cats to install test pipes.
Should I just hold on to them or is there a demand for these?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 02-06-2017, 10:07 AM   #2
JayG's Avatar
Hold on to them as you may need them one day for smog testing
They do have a value, even as scrap. They have platinum in them that can be recovered
Old 02-06-2017, 10:11 AM   #3
Carlisabadman986's Avatar
I have heard this before. Any idea roughly how much the platinum is worth? And would pay me a scrapyard?
01 Base Arctic Silver, Top Speed Muffler and Cat Delete pipes, Ben006 Short shifter
Carlisabadman986 is offline   Reply With Quote
Old 02-06-2017, 01:47 PM   #4
Check with a muffler shop...they usually have someone that comes around and collects the scrap exhaust stuff.
Old 02-06-2017, 02:02 PM   #5
steved0x's Avatar
Open them up, take out the core, maybe you can get some $$$ for it at a recycling/reclamation center, weld it back together for stealthy but heavy'ish (unsure how much weight the cat block is) cat delete mid pipes... With built in heat shielding for your inner CV Boots
Old 02-06-2017, 02:41 PM   #6
JayG's Avatar
Do a web search for recycling cats
Old 02-07-2017, 05:20 AM   #7
$25-50 depending on what scrapyard you take them to. Helps to cut off the tubes too.
Woody
