Old 01-18-2011, 06:36 PM   #1
3.2 boxster S engine part out
I have everything other than the IMS and crank engine has 80k
Spun a rod bearing. crank was junk and one rod.
6 good Pistons 250 set
injectors 200
perfect case 700
intake 140
1000 mile oil air seperator 40
good oil pump 75
fuel rails 120 both
5 rods, 60 each
perfect redone heads ready for install
3.2 cams
anything else..
johnnyd8998 is offline   Reply With Quote
Old 01-21-2011, 01:40 PM   #2
BYprodriver's Avatar
What year car/engine & is it the original engine?
Old 01-21-2011, 02:37 PM   #3
this was from a 3.2l 2001 boxster s. This was the original engine.
Old 02-16-2011, 08:35 AM   #4
No one needs any parts from a 3.2?
All great parts, hard to find heads ready for install, a perfect case to build, pistons, rods for other rod bearing victims.
Old 02-16-2011, 03:36 PM   #5
Do you still have the crankshaft? How much for it?
Old 02-16-2011, 03:43 PM   #6
Crankshaft was junk.
Old 02-17-2011, 12:53 AM   #7
heads
How much for the heads shipped to 78258
goldsc_78258 is offline   Reply With Quote
Old 02-17-2011, 08:06 AM   #8
pm sent on the heads.
Old 02-17-2011, 10:22 AM   #9
Old 02-17-2011, 10:51 AM   #10
I have it, its .0014" bent. but 100 bucks
Old 02-20-2011, 03:04 PM   #11
[QUOTE=johnnyd8998]I have everything other than the IMS and crank engine has 80k
injectors 200
perfect case 700
intake 140
good oil pump 75
fuel rails 120 both
5 rods, 60 each
3.2 cams
anything else..[/QUOTE
Do you have a purge valve part #996-605-201-01?
trandinh66 is offline   Reply With Quote
Old 02-20-2011, 06:44 PM   #12
yes I do I will varify the part number and give you a fair price on wholesale replacement value.
Old 02-20-2011, 08:43 PM   #13
do you have the right rear catalytic convertor?
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 02-20-2011, 09:29 PM   #14
Jaxonalden's Avatar
What year is your 3.2? I'm interested in your air/oil separator as long as your engine is an '03 or greater. Part #996-107-023-04-M100 for '97-'02 and part #996-107-026-01-M100 for '03-'10.
Old 02-22-2011, 01:13 PM   #15
pm replied to on the aos. Sorry the cats are not for sale at this point.
