		|  04-14-2021, 06:10 AM | #1 |
	| Who's askin'?
				vinyl wrap in Arctic Silver color
			Hi y'all;
I've searched and searched because I know I've seen it on this forum, but I can't find it.
Does anyone have the information about the Vinyl Wrap that matches the Arctic Silver?
Thanks In Advance!!
		|  04-15-2021, 10:29 AM | #3 |
	| Who's askin'?
					Originally Posted by Starter986   |
aw you're a good man, Starter!!
you wanna see why I need it?
Check this.... hahaha
https://youtu.be/PDForwCdN_c |
		|  04-16-2021, 05:56 AM | #4 |
	| 1998 Boxster Silver/Red
					Originally Posted by maytag   |
Nice 'wait for it' vid!
Wow. Good thing you weren't on a curve. Any damage other than paint? Which hood pins are you going to install? Which brand of oil were you running, and why?
				__________________1998 Porsche Boxster
		|  04-16-2021, 10:32 AM | #5 |
	| Registered User
Knew it was coming, couldn't stop watching. Glad it wasn't worse!
Just to memorialize this, I stopped by my local graphics shop yesterday and they pulled out their sample of the Avery Silver Metallic SW-900-803M and compared it to my stock paint (1999 Boxster, Arctic Silver Metallic). Really, really close if not spot-on. If you're trying to match something, it's a good place to start.
		|  04-16-2021, 01:04 PM | #6 |
	| Who's askin'?
					Originally Posted by Starter986  Nice 'wait for it' vid!
Wow. Good thing you weren't on a curve. Any damage other than paint? Which hood pins are you going to install? Which brand of oil were you running, and why?   |
destroyed the windshield.  And now the hood looks like this.     |
		|  04-17-2021, 01:14 AM | #7 |
					Originally Posted by maytag  destroyed the windshield.  And now the hood looks like this.    |
The wrinkles add character.
Be safe.
		|  04-17-2021, 05:02 AM | #8 |
	| Motorist & Coffee Drinker
			At least the old frunk lid will look good hanging on a garage wall.
				__________________I am not an attorney, mechanic, or member of the clergy. Following any advice given in my posts is done at your own peril.
		|  04-17-2021, 07:11 AM | #9 |
	| Registered User
			Wow, nicely modulated, controlled response on your part—only a slight arm movement.  When that thing came flying up, I think I'd have ducked at least a little!
There's a local road course track in this area that has an overpass for the access road.  It's on one of the two straights, and it's pretty low, not a whole lot of clearance above the car when you drive under it.  Every time I've ever driven that track I always duck—just a little—when I go under it.  It's an ingrained reflex.     |
		|  04-17-2021, 12:10 PM | #10 |
	| Pathological Tinkerer
					Originally Posted by Starter986  The wrinkles add character.
Be safe.   |
Also more front downforce..
		|  04-17-2021, 07:27 PM | #11 |
	| Who's askin'?
					Originally Posted by Frodo  Wow, nicely modulated, controlled response on your part—only a slight arm movement.  When that thing came flying up, I think I'd have ducked at least a little!
Thanks frodo!
I was impressed I didn't say any bad words!  Haha
		|  05-17-2021, 01:56 AM | #12 |
	| Registered User
			Has anyone wrapped their bumpers instead of re-spraying?  I need to do mine (front mostly) spider cracks and pitting from road.  Seems like if I have it resprayed, it will just happen again.  I was quited a while back about $600 to spray both front and back.Taking car to shop next week, possible immobilizer issue, but I am hoping it is just ignition switch.  After pulling immobilizer to check it for damage, car won't start.  Odd thing it, when you turn the key, the frunk unlatches!  Then it would not unlatch, but would not open no matter what, and alarm would not stop.  So I had to pull the inner wheelwell to get to emergency release and disconnect battery.  OoFF!
 2002 Base Artic Silver
		|  05-17-2021, 07:48 AM | #13 |
	| Registered User
			I believe that any cracks or pitting in the paint would show in the wrap unless the surface was refinished prior to application.
		|  05-17-2021, 11:22 AM | #14 |
	| Registered User
			Doing a wrap on anything plastic isn't going to turn out too good or last.  You also have to have it perfect...no chips, dings, cracked, peeling paint, etc.  Either sand it down & primer it for a wrap or have it repainted and get a clear bra.
				__________________2000 Boxster Tiptronic
 2003 Boxster
 2003 996 C2 Cab
 2002 996 (SOLD)
 1986 944 (gone but missed)
		|  09-10-2021, 05:27 PM | #15 |
	| Registered User
			Avery Dennison gloss metallic silver is a dead match for porsche Arctic silver. I wrapped my headlights today. Will post pics after I get the bezels mounted.
				__________________2000 Box Base, Renegade Stage 1 performance mods complete, more to come
		|  09-12-2021, 09:29 AM | #16 |
	| Registered User
			Ok, maybe not as perfect as I first thought. We'll see what it looks like when I get everything washed up. Not too shabby though for $50 bezels and $15 worth of vinyl!
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 HTML code is Off
 |  |  |  All times are GMT -8. The time now is 01:00 AM.
