07-07-2014, 10:46 AM
Detailed my engine compartment today
I did this stone cold and have not yet started her up. I used orange blast and a soft brush, used small amounts of water from a garden hose (no pressure washer) as I did not want to flood the engine compartment. I Used old towels to keep overspray off the trunk and interior. I used a new product on the plastic that does not leave an oily residue, after all if left oily it would simply collect dust and particles at a greater level than if left dry. I am pleased so far...we will see how this holds up.
07-07-2014, 11:11 AM
Looks very nice. I used the same process. Some orange cleaner and very low pressure water, soft brushes and rags. It's been awhile since I did it, probably time to do it again!
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
07-07-2014, 11:13 AM
Wow! That looks great!
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
07-07-2014, 11:21 AM
nice job Dwight !
Time to keep up with the Jones'
07-07-2014, 02:12 PM
1998 Boxster
What was the name of the product that you used on the plastic?
07-07-2014, 02:19 PM
Turtle Wax
Tire Black, comes in a small rattle can and packed in a box. 10 bucks and change. Dried to a very dry to the touch finish in about 2 hours.
Turtle Wax Black Tire Shine: Auto Detailing & Car Care : Walmart.com
I also masked off my flaps on the front and back and cleaned them and treated..they look great...we will see how well it holds up
07-07-2014, 02:45 PM
Will the tire black stuff just burn off or do something funky in the 180 degree engine compartment?
07-07-2014, 02:55 PM
Good Question
We will see....it has to be better than the layer of dirt and dust that was there and better than armorall
02-01-2016, 05:52 PM
Looks good. Question. I just cleaned my throdle body and started cleaning like you with light water and degreaser the outside's of engine. When i took off the main air plastic tube that goes to the throdlebody from the airbox. Right below,i guess where the engine meets the transmission. You can see on the top of the block a little crack that i can see into i guess would be the flywheel or clutch?This normal? Does not look damaged but looks like it could have or should have a rubber capping or cover on it? I can see water/dirt easily getting in there and gumming it up over time.Guess a picture of it would help. So basicly i stopped washing in there. You would think engine/trans blocks are fully case/sealed no?
02-01-2016, 06:17 PM
07-07-2014, 03:14 PM
Yeah, I'm interested to see as well. If it holds up fine then this is a great solution to keeping the engine looking good.
The other option is to use ceramic/high heat engine paint or gloss, but then you risk chipping and eventually it will look like crap
07-07-2014, 03:31 PM
Paint
I would only go that route if I had the engine pulled and could paint individual components. I have never seen a engine painted installed that looked really good. If I were going that extreme I would get one of the home powder coating systems and do that
07-07-2014, 05:10 PM
Looks great. I haven't looked at the engine compartment yet, only get home once a month, too little time....
07-10-2014, 06:44 AM
Looks AWESOME! My engine is filthy and it drives me nuts. Been busy on other projects but you have inspired me. this is on my to-do list. then I can think about a clear cover like Shehadehd. I think that is soo cool!
99 Porsche Boxster
07-10-2014, 07:03 AM
problem with the Turtle Black is that in my experience it still attracts dust and there's plenty sloshing around in there... unless you live somewhere where there's not much rain and not too much heat.
I would use a product like Klasse VLRP next time or similar from autogeek.net or some other detailing site. But maybe your result will be better since its a closed space.
Your pics make me wish that Porsche had incorporated a visible engine into the 981 design like the Ferraris.
07-10-2014, 07:33 AM
I did that a couple of times. It looked pretty good for about a week and then shortly looked like I just ran Paris-Dakar.
I wondered why this motor gets so nasty so fast? Then I looked at engine compartment ventilation. Oh my... those little rubber flappy things under the trans pull air from inches off the road and circulate it up, creating positive pressure in the engine compartment while cooling the trans, rear brakes and engine oil cooler. Our cars are like little street sweepers vacuuming up a ton of road grime and depositing it into the engine compartment. This explains the Paris-Dakar level of filth.
I still wipe down the engine when I open it up but no longer use detailing tactics. All my good work will be completely dusted over in one good canyon run up Angeles Crest Hwy.
07-10-2014, 07:34 AM
2 weeks
I plan on adding rear speakers in the next 2 weeks. I will pull the cover off ands see how it is fairing
I know when I buttoned it back up the finish felt very dry to the touch and slick.....only time will tell. I also did my engine compartment on my E36 so we can see how that holds up as well
07-10-2014, 11:37 AM
I want to clean my engine but what about water and electrical parts under the hood? did you cover anything off so it wouldn't get wet? Did you just use a simple green type of cleaner? then hose it off?
99 Porsche Boxster
10-28-2015, 06:41 AM
Project Addicted
This is the best way to clean up sensitive parts as well as extremely dirty greasy parts. Amazing how good the steam is and how little water it really uses. The heat and the pressure just blasts the dirt away. the tool comes with different brushes and other tips. It can also be used around the house :-)
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
10-29-2015, 05:10 PM
jsclocum: more or less, how much does this steam machine costs..?
HTML code is Off
