Thread: Simple Question
Old 05-15-2007, 09:10 AM   #4
alikhan78
I would also factor in the cost of the various tools/equipment needed for the rebuild.
Originally Posted by johne4
A quick look through the ******************************************** parts catalog indicate that you can get everything you need to rebuild your motor. Adding up the cost of the soft parts such as bearings, seals, gasket, etc and even adding new pistons and rings comes to less then a grand. But for the hard parts thats a different story.........3k for a crank?.............
I guess the question is when is it worth rebuilding versus replacing.......
In my opinion if you are rebuilding your motor because it is worned out i.e. low compression, oil blow-by, low oil pressue and the motor is still running, then yes I would rebuild my motor.
Now, if you wait till it blows up damaging internals, you probably better off replacing the motor with a remanufacture or new one.
alikhan78 is offline   Reply With Quote
