Originally Posted by mjstallion
I just got my system installed, and there was a little bit of whine when the music was very low or when the navigation was going. I went back to the installer and he put in a filter and now there is no whine.
It seems that filters are viewed as bad on these boards, and I was just wondering if I should go to a different installer and have him remove the filter and fix the whine by other means...
it depends on how powerful your amp is. if you went to a cookie cutter type installer (best buy, circuit city), they won't re-wire it for you. if you went to a high end place, there's really no excuse for not properly routing / shielding the cables. if your amp is low power, the filter is fine. if you're concerned with overloading the filter, add another one in parallel.
