Old 08-30-2004, 11:10 AM   #1
Hunderman
I have the mesh inserts, but they rattle against the metal rollbar. The inserts are hard plastic with three integral clips. Each clip has a soft "rubber" pad which, I suppose, is to isolate the plastic from coming into contact with the metal rollbar. Some of these "rubber" pads have moved, but not enough I thought to cause the rattle.
Does anyone else have this problem and how did you fix it?
Hunderman is offline   Reply With Quote
