Crank to cams guides?
I have seen a lot of discussion on this and other forums about replacing the variocam ramps for the cam-to-cam timing chain. I have seen mention of other timing chain guides for the crank to cam timing chain but I have not found much about replacement of those. I assume it is prudent to replace them at the same time. Any advice on that?
It seems when I search on 986 timing chain guide or ramp replacement I only get instructions on replacing the variocam ramps. It there any good videos or the like for addressing crank to cam timing chain guide replacement?
Thanks in advance
