Old 04-13-2025, 02:51 PM   #2
piper6909
piper6909's Avatar
I think you are referring to the RMS seal failure issue, which was the result of two failure types:
  1. The original seal was a Viton based unit that did not have the life expectancy and was replaced by a PTFE based seal, which worked.
  2. Out of round case openings which would leak regardless of the seal material used. These were the result of machining issues and Porsche released a "concentricity" test tool that was a go/no go test that was used if the engine was still under warranty; if it failed, the engine was replaced as it could not be corrected in the car.
There was also a non concentric IMS shaft problem, where the shaft would wobble because the IMS bearing center line the the shaft center line were not the same. This was mostly in the early 986 engines and was enoght of a problem that engine rebuilders had problems finding enough usable shafts to reassemble the engines, but that had nothing to do with the engine cases, it was a shaft assembly problem.
I may have gotten those issues mixed up, then. Thanks for the clarification. In that case, I see no justification for the advice that mechanic gave pianoporsche.
2010 Subaru Forester
