Old 12-30-2024, 02:23 PM   #1
Marc_986
What suspension kit did you order?
As far as the Bilstein shocks go (I guess you are referring to them), the black B4 is OEM replacement, should work as original on original suspension. Then there is the yellow B6 which is stiffer (so to say) which can go with standard springs or with the sport springs. If your car will get really lower, you should consider the yellow B8, which is a shorter variant of the B6 (as far as I've heard, some say these are also stiffer than the B6, most say they are identical but shorter).
I've just put on B6 with the M030 ROW springs which should be an ok combination., Will find out when spring comes.
Marc_986 is offline   Reply With Quote
