Old 11-18-2024, 08:09 PM   #1
bigbuber
The water pump is in the center of the engine not the right hand side of the engine.
If you have coolant draining near the right rear wheel that is where the coolant tank overflow tube is.
There is no possible way for a failed water pump to cause coolant to leak into the trunk area.
You could possibly have multiple coolant system issues.
Failed pump...failed coolant tank....failed coolant hoses.
Do a proper pressure test of the system then you don't have to guess what or where the issue is.
If your taking it to a shop then they should do there own diagnosis.
It leaked from the right side because of the skid plate. If you watch my video, you can see coolant leaking heavy from what I assume is the water pump. Can someone confirm?
And who knows why there is leaked coolant in the trunk and the pump area. Probably unrelated but idk
bigbuber is offline   Reply With Quote
