Thread: 986 engine swap
Old 09-03-2024, 10:59 AM   #3
78F350
Motorist & Coffee Drinker
78F350's Avatar
The easiest engines to swap will be model year 2000 through 2002. The earlier and later engines will require more extensive modification.
In 2002 986s started using a non-return fuel system where the fuel pressure regulator is in the tank instead of on the fuel rail. If you install a 2000 - 2001 engine, keep the fuel hoses from the original engine. There may also be a different coolant temp sensor (2 wire vs 4 wire, I forget which engines have which). As you suggested, it keeps things simpler if you move your original harness, sensors and intake to the new engine.
