Old 09-07-2023, 06:50 AM   #10
blue62
Testing Evap Purge Valve for vacuum leak:
Disconnect the hose from the intake to the valve. (at the valve).
Disconnect the Electrical connection.
Apply vacuum of 0.7 bar to the valve.
Vacuum should not fall below 0.5 bar after 10 minutes.
That will tell you if it holds vacuum correctly or not.
