Old 08-01-2023, 07:35 AM   #2
Lacostas
Yes. It will be a little messy, but you have intermix already. You can minimize the mess by lowering the level of coolant in the expansion tank. I've used a turkey baster for that (do not use it for basting turkey afterward).
In most cases of intermix the problem will turn out to be a cracked head, especially in 2000 models. I actually did have one that was bad O-rings on the oil cooler though.
Hoping for the best.
Thanks for the fast reply!
Okay - ill try to lower the coolant level somehow before trying. In any case, ill take the chances and proceed with it as it.
My model is a 2004 2.7L one. Lets hope for the best
In case there is a cracked head, any cost estimation available ?
Lacostas is offline   Reply With Quote
