Old 10-17-2022, 07:40 AM   #3
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by tommy583 View Post
... The front drain on the drivers side near the battery was plugged. There was a lot of water trapped there. So much so that when I moved the car last week and saw liquid running out of the bottom of the car I now think it was at such an angle that the water was running out of a high spot on the wall with a missing grommet....
Tommy, I had that happen on a 1999 and some water leaked into the brake booster. before I realized water got in, it developed rust inside and the brake pedal started to bind. If the water was high enough to reach the boot on the booster, you may want to find a way to check for water in there.
