Old 06-06-2022, 11:15 AM   #3
jax944
Originally Posted by elgyqc View Post
You don't seem to be getting much help, so here is my 2 cents worth. Get an OBD reader, even a cheap one might give you some indications of what is going on. Try starter fluid in the intake (remove the air filter for access?). Pull a spark plug to see if you have a spark. Engines still run on 2 things, fuel and spark... plus the will of the electronics gods... which depends on a few thousand other things.
I have 2 obd readers and 1 of them is the durametric software for a pc. Until I can get the car to start and generate codes.... both are useless at the moment.
jax944 is offline   Reply With Quote
