Old 01-24-2022, 06:40 PM   #1
ike84
It's more frequent for a cat to plug and do what it did on your mustang than it is to see one fall apart from the inside like your rover.
Your smell may be a small oil leak (spark plug tubes are common culprit, drip into exhaust piping).
What does the noise sound like? A rear end rattle could be a lot of things.
I'd get the car up on jacks and have a look around to figure those two things out.
A fluctuating idle can mean a lot of things. If it's only with cold startup at idle, it's likely a small vac leak. Do a manifold vac test and see what that shows you.
Sent from my SM-G970U1 using Tapatalk
