Old 01-06-2022, 01:21 PM   #7
dsallean
Last set of headlights I sanded was for the conversion to LEDs. To do so would require removing the lens and the inner burnt lens. But since I had a spare set of headlights I wasn't too worried about ruining them (well, maybe a little) and I only used two grits of sandpaper then switched to wet sanding with Abralon pads. What a huge improvement the Abralon pads were. They are expensive but I had them left over from another project and I used up to 2500 with the Abralon and it was amazing how fast and easy those pads are in getting the job done. Good luck.
dsallean is offline   Reply With Quote
