Old 12-01-2021, 10:07 AM   #11
Radman
DISCLAIMER: try this at your own risk. Your results may vary.
I've never had any luck with the Dr Colorchip dab and swipe method. But here's what I've found works well for me, esp with deep scratches.
I'll carefully paint in the scratch with DC paint. It will leave a ridge above the rest of the paint. Use as small of a brush as possible and just fill the scratch, no need to slop over onto good paint. Let it dry thoroughly. Next, take some 1500 sand paper and water and wet sand the scratch, being careful to sand as little of the good paint as possible (ie, a 1/4" on either side of the scratch). Go slow, go easy - you don't want deep sand scratches. Use plenty of water. You may need to repeat painting some areas if the paint hasn't fully filled the scratch.
Once you have the surface smooth and the scratch is filled and gone, use rubbing compound on the sanded area, going out an addl 1/4" on each side of the scratch (so now 1/2" ea side of the scratch for a total of 1" across). Focus the effort on the scratch area with some blend out from the sanded area.
Step up to a swirl compound (a mild rubbing compound) and expand another 1/2" on each side of the area. After this step, the area should have a decent shine and the scratch should be gone.
Finish with a polish and then wax, expanding the blend area out even further. These steps work best with a polisher but can be done by hand, they just take a bit more elbow grease.
Take your time, be easy, work in as small an area on ea side of the scratch as you can. It's always easier to go back and repeat than to go too far - no going back then.
This method also works on rock chips, just in smaller doses.
I've had great results with this method on scratches and chips.
Thanks for the advice! I have tried very light sanding but not with water. I may need to try different touch up paint. It does to appear to be a little bit of a lighter shade. Works great for small spots, not so much on larger rock chips and scratches such as this. This particular scratch was down to the metal.
The spot on the back is compromised clearcoat somehow and looks like the deck was slammed shut on something that dented it from below. I've made minor improvement there as well.
Radman is offline   Reply With Quote
