Thread: Strut dilemma
Old 09-29-2021, 08:38 AM   #1
Quadcammer
take the weight off sub the hub is hanging. Then it should be mostly free to move on the strut. push down on hub until bolt holes line up.
no biggie.
As for the plate, sometimes they don't like to go back on. The idea is to locate the subframe uprights, to which the lower control arm and toe arms bolt, wrap a ratchet strap around both sides, and cinch down until the studs line up with the plate holes. With the plate off, they have a tendency to spread apart a bit. Sometimes an issue, other times not.
