Old 07-26-2021, 01:25 PM   #11
elgyqc
elgyqc's Avatar
The car is back on the road, I only got the rear wheel bearings done, the fronts will be done... soon. The "new" engine seems to be fine.
While I had the Durametric on it I checked the Airbag codes and the list is long, but the important ones are:
"3 - Supply voltage
195 - Control module internal fault - All fault codes over 100 indicate a critical fault and usually requre a new control module"
I will check the supply voltage at the connector, if it is OK it would seem the control module is toast.
Addition... I checked the supply voltage and it is OK... so it would seem that the module is defective.
Still haven't got an oil pressure gauge. I think the sensor unit is defective, but that can wait.
Grant
