Old 06-13-2021, 09:27 AM   #10
ecp
i pulled the exhaust cam, a definitive broken valve spring broken on cylinder two, need to pull the intake cam to look at the intake springs on cylinder two or one.
Do you guys think i need to pull the head? i’d definitely like to avoid that if i could. I’ll probably end up replacing all the valve springs if two simultaneously broke to be safe.
also any tips on reassembling? i marked the chain and sprocket with a marker and have the lock tool from my Ims kit. it’s a variocam 3 chain motor
ecp is offline   Reply With Quote
