Old 10-02-2020, 05:47 PM   #5
dghii
Yeah, that vise has been like that since I moved here from my previous place... Maybe once the Porsche engine is off the bench!
If I burned out the bushing I`d end up with a steel cyilinder in an aluminum bore that I still would have to press out.
For next time, mount insert removal is easy if you cut the rubber out and then use a hack saw on the remaining aluminum. saw a couple of cuts and the aluminum comes out in a couple of pieces. About 30 minutes total.
dghii is online now   Reply With Quote
