Old 06-15-2020, 03:26 PM   #27
JFP in PA
Fair enough. I totally get that, on principle, a plain bearing is far more durable than a ball or roller bearing. So you're saying you won't install LN's other bearings, only the "solution'?
I agree with you that it's a fine product, and there's a solid argument to be made that it's actually the best out there. But when it costs at minimum twice as much as anything else out there, don't you agree that they can offer a much better warranty? I mean, seriously. After all the pre-qualifications, and to only honor the warranty if it's installed by an authorized mechanic, don't you think they should believe in their product enough to offer a lifetime warranty? To me it screams that they don't believe in it, not even as much as you do.
I have installed many of both style LN bearings, and have even uninstalled LN ceramic hybrids to replace them with the IMS Solution (two in my own cars as a matter of fact). When the Solution was first released to the public, it was only available in a single row configuration, the dual row came much later. So at one point in time, if you had a dual row, the ceramic bearing was your only choice unless you sent the car to Jake's shop, as he was the only one installing the dual row Solution before it was release to the general public. The IMS Solution is a better answer, regardless of the price, if you intend to keep the car for a long time, race the car frequently, and particularly if you have a Tiptronic trans, as it never has to be replaced. It is also the only retrofit that can be pulled out of one engine and successfully installed in another with out issues.
