Old 11-10-2019, 12:58 PM   #2
AZ986S
AZ986S's Avatar
I chased that same problem for some time, because the engine would seemingly run and did not make any funny noises. Tried a new oil filter, new oil pressure relief valve, new oil pressure switch, thicker oil...
The issue was much more serious (broken valve retainer that got swallowed up by the oil pump). Dropping the oil pan was what provided positive diagnosis. Ended up putting in a new engine.
So, yes, as has been mentioned in previous posts, low oil pressure could be a sign of more serious issues, so I would not drive the car.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
