FS: Cleaning out the shop, I need to get rid of a ton of parts
I need to clean up my shop and make space for my 944 S2 which is sitting outside. I need to get rid of these parts. If prices are too high, please make me an offers. Prices do not include shipping.
S Brakes, rotors, pads and rear suspension/ebrake assembly. Make me an offer. The calipers have a few marks on them and the clearcoat is starting to show on a few of them. The rotors are within the min wear spec by about 1 MM. The rear pads need to be changed.
Drivers side tail light $50.00
Tiptronic clock spring - $40.00 Sold
Xenon Computer (996-618-051-09) - $20 Sold
Xenon level sensors - $30 for both Sold
Drivers / Passenger Side Door Harness - $20 / Each
Front trunk wiring harness (car had xenons)- $40.00
Drivers side headlight bracket - $40.00
Headlight switch - $75.00
Complete black interior carpet set - $125.00
Complete Front Trunk Carpet Set - $75
Complete Rear Trunk Carpet Set with foam bottom pieces - $75
Cupholders – (For parts, some pieces are missing) - $20.00
Upper console frame that was modified for a double din stereo - $20.00
Lower center console frame with upper storage bin and boxster s insignia - $50.00
HVAC Climate control display (one dead pixel) - $75.00
Boxster S sill plates - $25 each
Silver center console and window button tray (has a few scratches/chips)- $100 - SOLD
Tiptronic gear selector trim - $30.00
Black dashboard - $40.00
Ebrake lever - $40.00
Lock button / Defroster Button / Convertible Button / Cig lighter - $10 each or you can have the trim piece with all of the buttons for $25.
Wiper motor and linkage - $50.00
Tiptronic flex disc - $25.00
Tiptronic starter - $25.00 Sold
K&N 33-2773 Air filter (washable / reusable) - $15.00
986 Airbox (without MAF) - $50.00
986 Airbox tube - $25.00
Passenger side exhaust manifold - $100.00
Drivers side / Passenger side mid pipes - $125.00 for both
986 engine cover (from top)- $25.00
986 engine cover (from cabin) - $20.00
2.7L Muffler (stock) - $75.00
Heater core - $30.00
Master Cylinder / Brake Reservior / Brake Booster (all assembled in one piece) - $75.00
Tiptronic alternator - $50.00 Sold
Both litronic headlight washers - $50 for both
Stereo AMP - $20.00
Complete evaporator/blower housing assembly/box - $100
Front radiators with fans - $100 each
Front radiator brackets - $20 each
Tiptronic shifter - $40.00
Tiptronic shifter cable - 25.00
S front suspension pieces - make me an offer
S Rear suspension - make me an offer
Steering rack - $75.00
Secondary air injection pieces - make me an offer
Parting out a seat - let me know what you need
2000 Porsche Boxster 2.7L Fuel Injectors and fuel rail - make me an offer
half worn clutch disc, pressure plate, flywheel (unsure about flywheel condition)- make me an offer
Steering column with ignition switch - make me an offer
2.7L cooling hose set (all cooling hoses for the front of the car) - make me an offer
I have a ton of other misc parts if you can think of anything.
Pickup
Gas tank – free
2.7L cooling pipes - free
Duralast 94R-DLG battery (in good condition) - $20.00
OEM Glass soft top that the previous owner converted to a manual top (by cutting the tabs where the pushrods mount - $150)
17” S twist wheels (some marks)- $200
Passenger seat - no tears but center insert is starting to come out - $50.00
