Old 08-30-2019, 07:31 PM   #16
Paul
Porsche "Purist"
Paul's Avatar
Originally Posted by paul View Post
you will need your radio code.
You will need to roll the windows up (with the top closed). Then push and hold each window switch for a few seconds to allow the closed position to be relearned.
To relearn the idle position of the gas pedal, turn the key to the run position (do not start or touch the gas pedal) until you hear the throttle click (about a minute). Then turn the key off for about 20 seconds and then start the car.
Everything will work except the radio, but do the above.
1987 924S. 2002 996TT. PST-2
