Old 03-27-2019, 07:30 PM   #1
jaykay
jaykay's Avatar
Hi there this MAF housing is the same diameter as the stock 986 housing which is incorporated built into the stock 986 airbox (04 550 anniversary excepted). With its use the stock mass airflow calibration is maintained. There is no need to re map or retune the car. One would make use of this when installing a 987 airbox or custom intake without having to cut out the stock airbox MAF piece or making one from scratch. IIRC just 1mm out on housing diameter can affect MAF calibration which in turn affects A/F mixture; fuel trims; engine performance.
986 00S
