Old 01-22-2019, 11:36 AM   #16
Homeoboxter
Originally Posted by marsheng View Post
The ring gap will seldom change down the bore. The ring wears and opens up the gap. If there is wear in the bore, you will feel a lip just above where the ring stops at the top. No step, bore ok.
Yeah, I checked that, I think the bores are fine, there`s no lip. It`s possible though that there`s some ovality, and the wear may be different along the bore due to the different piston speeds at different heights. So I`ll measure this just in case. BYprodriver also had a fair point when suggested that if the wear is substantial I may have a better seal with the original rings in the same position than with new ones. But most likely it`ll be fine with a fresh ring set once I find one. I think I`ll just go ahead and order a set for the 2.7 and send it back if it doesn`t fit, but I doubt that.
