Old 12-10-2018, 07:25 AM   #2
thstone
Originally Posted by Anker View Post
Sticking calipers could be the issue. Check the temperature of the wheels after a drive. If they are excessively hot you probably have sticking caliper pistons.
No, your experience is not common. The new brake pads and rotors should have solved the problem. But since it has returned, it is being caused by something other than the pads/rotors. I agree with Anker, the problem is most likely sticking calipers.
